Wansworth
Opinions about this yacht ,for sale here in Galicia
The one in Corunais 9,000eur..Quiteexpensive for a small boat but prices are higher here as less choice in Galicia.Its the type but the one I saw advertised was in Coruna,will check it out,thanks
Loosening a bitofinterestinthis boat,seller does not reply and worried about buying problems with water absorption and lifting keel problems.Maybe you can borrow a moisture meter from somebody?
Or even if you just use a 'cheap' moisture meter, such as what you might use for finding moisture in masonry walls, this might (I say might, I am not sure) tell you if there is water in the foam, if you compare the reading with an area that is known to be dry?
