Daydream believer
Just as a small thread drift, I wonder if forumites appreciate just how much effort can be required to put together an accurate quotation / estimate for some of the jobs done on boats? In an industry where there are few standard products, almost every job will include working in a different location, with the attendant difficulties in estimating access time, lengths of cable runs, un-fixing previous bodges, locating replacement parts from small volume manufacturers etc etc. And if the engineer doing the job then finds he needs a "special" tool, the odds are that it is back in his van which is 15 minutes walk from the boat. Or worse, back at base an hour's drive away.
So be understanding when your engineer declines to make a quotation, or is slow in coming back to you with an estimate, or makes an estimate which subsequently proves inaccurate. (In which case he should be communicating with the customer as the job goes on and the variance mounts up.)
Very poor. You are trading as a specialist (or one assumes that you are) in the work for which you are quoting & should know what you are doing.
I have quoted for £ millions in my working life & have always had to stand by my quotes. Just because one is a small trader does not make it any less important. Lackadaisical attitudes or a failure to understand simple procedures is no excuse. If you have made a mistake then that is your problem, not the customer's.
But on a slight drift --a quote should be honoured by both parties & I agree that for every cowboy trader there is probably a cowboy customer. They deserve each other
