Erratic tacho
ArthurWood
21 Jun 2001
SW Florida
The tachometer on one of my engines has begun to give erratic readings, sometimes showing ~2/3 of actual and sometimes the correct reading (as indicated by the sync indicator vs the other tach). It does not fluctuate rapidly. Is the signal from somewhere on the alternator?Belts seem OK.
Any thoughts on where I shld begin troubleshooting? Engines are 7.4l Merc petrol on 37ft Sea Ray.
TonyBrooks
10 Nov 2003
Berkshire UK
Without more info, difficult to know.
Petrol engines are likely to pick it up from the coil.
Any engine may use an inductive pickup from something "toothed" on teh crankshaft or camshaft, but in the case of camshaft pickups the guage needs matching to accept half engine revs or the "toothed" item needs twice as many teeth.
Any engine can get a signal from a single phase tap on teh alternator. The erratic nature of your fault leads nme to suspect a loose terminal (first thing to check) or possibley a dry joint or diode fault inside the alternator.
Tony Brooks
ex-Gladys
29 Aug 2003
Colchester, Essex
As said earlier the standard way of picking up a tacho pulse from a petrol engine is from the low tension firing pulse on the ignition. In a marine environment could be the inside of the gauge gungin up. Seen it on motorbikes where the wet gets in...
<hr width=100% size=1>Larry Botheras
Anderson 26 "Amber"
tr7v8
30 Nov 2001
Kent
It will be triggered from the coil. Is it electronic ignition, if it is it could be stray sparks if the plugs are getting a bit old. WOrth swopping the tachs over and seeing if it is the tacho or the wiring. If it is the tacho it would be worth while putting it somewhere warm and dry and seeing if that cures it. At the same time check the connections and see if they're clean especially the earth. If it is the instrument then a local repairer may be able to fix it cheaper than a replacement, try classic car repairers rather than specific marine ones.
<hr width=100% size=1>Jim
Draco 2500
ArthurWood
21 Jun 2001
SW Florida
for all your suggestions. I'll take a look when it gets a bit warmer. Temp hasn't risen above 60F here the past couple of days. Brrrrr.
ArthurWood
21 Jun 2001
SW Florida
Update
Can't easily remove tacho, so reached up behind dash/helm and sprayed CRC Electronics Cleaner on back of gauges. Seems to have cured tach prob and prob w/a temp gauge.
