ga1135
Tide really does affect the impeller reading, even on the way.
Try keep same fuel level and go up & down stream see how the readings behave.
Go for a measured distance up & down the stream also give you two different trip distance readings.
This 2 trip figures are also be used in the calculation when we re-calibrate the log setting for accuracy reading.
Using only SOG for relax cruising is fine. But having both log speed & SOG are very important when racing.
It helps you to decide whether to go closer to shore to reduce tide effect or go into the channel to follow the tide,
It also helps you to select the more favourable tack on the race course.
