sailinglegend420
"I think......," and "so in a sense......" are not really getting over your message. EVERY discharge cycle causes sulfation - as you say that is the conversion of parts of the Lead plates (and the H2SO4 electrolyte) into Lead Sulfate and water, PbSO4 and H2O. Charging reverses that process and the SO4 recombines with the H20 that has diluted the electrolyte which is why the SG values rise when charged. There are lots of + and - ions and H2 an O flying around as well!I think damaging sulphation is more due to being left discharged or undercharged than being over discharged (i.e. very deeply discharged) per se.
The discharged state of both the positive and negative plates is lead sulphate PbSO4, so in a sense sulphation occurs in every cycle, and any recharge process is desulphation.....
So sulfation is ONLY a problem if the battery is not fully re-charged because the Lead Sulfate crystals harden, and the longer parts of the plates are not fully charged the harder these Lead Sulfate crystals become, which makes it harder to remove them. If the batteries haven't been fully charged every 2 or 3 weeks then a high Equalisation voltage once a month should remove the hardened Sulfation.
I Equalise my Lifeline AGMs about twice a year, but now ONLY because they are showing signs of a lack of capacity after 10 years as a fulltime liveaboard. I wouldn't do it every month as Morgans Cloud recommend!
When I EQ them they only start to gas VERY slightly after about 5 hours, nothing like an FLA that bubbles vigorously. Nearly 100% of the gas generated is recombined into water and kept inside by the valve regulator cap that keeps the internal pressure at about 6 PSI.
I believe Red River AGMs also recommend equalisation. I think Nigel Calder also uses EQ voltages on his Odyssey TPPL batteries which seem to be giving him some capacity problems. If you have AGMs that have lost capacity then maybe there is little to lose if you EQ them. My Lifelines certainly come back up and maintain there voltage longer between recharges.
MikeBz's comment about US and UK different charging voltage I think refers to GELs NOT AGMs. They are very different types of battery and shouldn't be confused.
