epoxy
joeh
4 Feb 2003
asia
hi all
if you paintbrush epoxy thinly onto foam , will the epoxy be absorbed by the foam or will it still form a protective layer ? reason being this is in a small hole and i can't see properly. thanks.
oldsaltoz
4 Jul 2001
Australia, East coast.
G'day Joeh,
What type of foam will help, as some foams will be dissolved by resins, is this a foam sandwich deck?
Avagoodchrissie......
<hr width=100% size=1> Old Salt Oz /forums/images/icons/cool.gif Growing old is unavoidable. However, growing up is still optional.
joeh
4 Feb 2003
asia
g'day brian
don't know what type of foam it is but yes its a foam sandwich deck. boat is an old dufour from the seventies.
oldsaltoz
4 Jul 2001
Then you should have no problems.
Prior to filling, try to remove any contamination, dirt, sand salt etc, you can do this with a bent wire in a drill, then blow out the dust.
If the hole in the topsides, after applying a small amount of resin you can fill with a mixture of closed cell Micro Balloons or 'Q Cells' but it will need protection from UV, so a little dab of paint or Gel-coat will do the trick.
Hope this helps.
