ip485
PS - as a small tip, this is a remarkable product for finishing wood - for example table tops etc. It takes an age and is a pitta to build up varnish layers to make a beautiful cockpit or saloon table, but can be done in one pour with epoxy. I find it gives a very resilient finish (better than varnish). If it is outside it is worth applying a couple of coats of sprayed varnish for UV resistance. Inside I havent seen any need to do so on my saloon table which is now around 5 years old. Woodsealing the surface first is vital otherwise you will end up with an array of pin head depressions as the wood unevently absorbs the resin during the curing process, but this can be wet sanded back and poored over. It use surprisngly lettle resin as of course you are only aiming for 1mm or something like this of surface coat. (should know how to spell pour).
