Epoxy paint mixing.
  • Thread starter Thread starter KAM
  • Start date Start date
KAM
6 Jun 2005
I have run out of curing agent for my 5 to 1 paint but have plenty of curing agent for 3 to 1. Can I use the 3 to 1 with the 5 to 1. What is the curing mechanism with epoxy paint. It seems to cure rock hard at low temperatures where normal laminating resin would definitely not cure.
Epoxy setting is a chemical reaction, and requires the right proportions of hardener. Experiment as suggested before committing to using it where it matters. Insufficient hardener it will not cure properly,. Too much and it will not use all the hardener, which remains free in the epoxy, weakening it and usually leaving it feeling sticky. Either way it's a nightmare to remove properly!
