nmeyrick
I mixed up a batch of SP106 epoxy the day before yesterday using their slow hardener and microbaloons to make a fairing compound to create a waterproof barrier over an exposed section of hull to deck joint behind the bow roller fitting.
I have used the same hardener before and it had set hard after the amount of time that the current batch has had. The latest batch however is still tacky and pliable, but is much firmer than it was originally. I had mixed it to the consistency of mayonnaise and it now has the consistency of a firm putty. It is difficult to scrape a stick through it, and will hold the shape it is left in without flowing.
I had mixed it by measuring out with a spoon using the correct ratio, i would have to admit it may not have been 100% accurate but I have used the same approach in the past without success.
I don't have a problem it if takes a while to set as it is not load bearing, but obviously if it won't ever cure completely I will need to clean it off and start again. So the question is does anyone know how likely it is that this epoxy will eventually set fully?
My understanding from the reading I have done is that if the proportions were wrong it would not have set as much as it has and so it should go on to set properly given time but can anyone advise on this, or at what point I should assume it is dud and cut my losses?
Neil
Neil
