laika
There appears to be a rusty little dent in my (iron) keel (quite small). I intend grinding it back with a wire brush on an angle grinder, applying some rust converter, then filling with epoxy. The book I have suggests microballons as an additive for this task (presumably for ease of sanding) but elsewhere says not to use microballons below the waterline because they are porous. I'm presuming for this application it's OK because I'm not trying to make anything watertight but just checking in case the epoxy is actually supposed to"seal" here. And also a little bit because I have colloidal silica and low density filler and the smallest quantity of microballons I can buy here (a small bucket) is over a tenner and I'm a cheapskate...
