EPIRB
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
I have acquired a share in a yacht (long story).
There is an EPIRB.
A Global Fix by ACR Electronics, Inc.
On side (manufactured?) Date : 0405
Label on front says replace battery by : 08/2009
The plastic surrounding the antenna has perished (with age?) and disintergrated.
Should we bother replacing the battery?
Can we do it our self?
OR
Should we buy a new EPIRB?
I’ve got one of these in the garage in exactly the same condition. I came to the conclusion to just buy a new one but haven’t got around to doing it yet.
Interested to hear people thoughts as well ?
Check with the manufacturer. Sometimes you get a good discount on a new one for sending in the old one. The batteries tend to not be user changeable.
The battery cells are available but probably need welded connections to make the pack. The £260 gets you a test certificate to say it actually works, the seal checked/replaced and a new, probably 6 year, battery.
Sitting in a cheap liferaft (if it actually inflated!) wondering if the flashing light means the EPIRB is working can be avoided by following Blondie Haslar's maxim.
I think this is a no-brainer. If it was a year or two out of date it would be sensible to replace the battery but in this case there are probably other components and circuitry that have failed or are failing.
