Epifanes
I use Epifanes gloss as i have a lot of teak. Great finish if applied correctly. What i would recommend is splitting up a tin into smaller glass bottles to store as it skins over in one day in the tin if left unused .
Have you experimented with Le Tonk?
Not sure if Brian will be at Southampton Boat Show, he was in two minds last year, but if he is well worth looking at what he has on show and a chat.
S'pose it's painting a fence - for sitting on..?
Exactly my response. Almost like should I have a pint of bitter or a glass of champagne.
There are so many products in the clear(ish) finish range with different properties aimed at different requirements.
Well, yes, over several years. I've used it recently on some teak mounting blocks, but the 'joos' I have is frustratingly slow to dry.
This thread/query is really about the 'coloured' high-gloss yacht paint - not the clear varnish.
https://www.epifanes.uk/product-page/epifanes-poly-urethane-yacht-coating-2-comp
Not used the 2 pack stuff but used their paint for my dinghy as I wasn't sure about the hassle of mixing and use of the pack stuff. Was very pleased with the result but the pack is supposed to be tougher so sometimes wish I had used that.
2 pack is really best if sprayed or at least done in controlled inside conditions. Single packs have come a long way and personally I don't think it is worth the extra effort and risk to use 2 pack. I have always used Toplac on my sheathed wooden boat and even the Oxford Blue did not fade and typically lasted 7 or 8 years before recoating to improve the shine, not because it was failing. Relatively cheap and easy to apply.
Photo taken in 2019, paint applied in 2010
There are loads of YouTube videos showing how to get a nice finish, I always use 2pk and weigh the 2 components to get the appropriate amount I need.
My experience of 2 pack polyurethane has all been good. Some 20 years back I painted the top sides and deck using just a brush. Not necessarily a good idea but was a way to cover repairs and scratches. Not good at close examination compared to sprayed on finsish but OK for me. Since then I have had no trouble touching further damages and modifications. I found the paint itself lasts for years after being opened. The hardener not good as it does go hard if not sealed properly. Current hardener ok after 4 or 5 years if I remember correctly. The finish is hard and well able to taken cleaning solvents etc. So yes i recommend 2 pack but not white for decks. ol'will
