Epifanes filler
Lloydus123
5 Jun 2020
Hi all, I’m currently using epifanes one part paint system , I have the first coat of primer on , which have shown me some bits and bobs (slight cracks ) that need filling before the next coat of primer . Epifanes say I must use their brand of filler , however I can’t seem to source any , I just expected it would be stocked in most chandlerys, is there another filler I would be ok to use ? It sais not to use an epoxy filler
thanks
thanks
I normally use FEW filler from Bonda. The FEW stands for Fine, Elastic, White. It is a polyester filler which sands well and can be used between top coats too.
International interfill will do the Job, since both products are the same parent group.
You could try marine and industrial in Wroxham, they are epivanes distributors
