Enlarging a hole from 55mm to 70mm in fibreglass
Can I piggy back on this thread to ask for some related advice?
I have been chickening out of cutting some 150mm diameter access holes in the inner lining of my boat ( Sadler type construction with moulded glassfibre headlining and maybe 30mm clearance between headlining and deck). Question is, the best approach?
a/ holesaw
b/ jigsaw
c/ something like geeky describes
d/ drilling lots of little holes round the circumference
.... 150mm diameter access holes in the inner lining of my boat ..... maybe 30mm clearance between headlining and deck). Question is, the best approach? ...... d/ drilling lots of little holes round the circumference
If depth control is critical I would use the small holes approach and set the depth bar on the drill (or make up a depth limiter and tape it to the drill). Then clean up the cut with a small diameter sanding drum, flap wheel. I would use a rasp to take off any peaks between the small holes first.
a/ holesaw
b/ jigsaw
A bodger writes ...
By a strange quirk of fate I had to fit three 150mm diameter access hatches to the buoyancy tanks of GRP dinghies last year. The first one I did with a jigsaw. I found it difficult to control and ended up with something like a lopsided 50p piece - luckily the flange of the hatch hid the horribleness.
For number two I drilled lots of little holes and then used a padsaw to join them up. Worked fine, but time consuming and the postage-stamp-perforation edge might be an issue in some cases.
For the last I was given the sideways cutting drill thing. I put a few holes round the circumference and then went for it. Lovely smooth hole in about 2 minutes. Light sanding only required for a beautiful smooth finish.
This is the sort of thing:
JtJKbgPGxzal1YOxEbZqfEzYNYwbbpwFN2hn88LmmFAa-Mgf3Wh7uNciuXJ8C9zQosP2c_mdef-ujukQtNf93YjjKanwCj7YJ_QOhk1hiVU0CkRHXCk8ocP5_pAKuP9sjP5PZBmX4QJvsCSZ6J2Rj1uhaSK0kpd72A6IYGGIvDwKH3tlMXHfxo2wd73JSpw01OwumCpQTDA
and Mr Google says eight quid for four. I don't think I'd want to try them on wood or metal, but on GRP they work a treat.
Edit: This thread has prompted me - I've just ordered a set from Amazon.
