demonboy
At anchor off the small island of Ko Lipe with nothing but Internet connection, some spanners and Calder's Bible.
Had a water hose leak on the engine so the engine was working fine this morning. Disconnected hose, made repair, reconnected, and now the engine won't start, just a single click from the solenoid.
Batteries are good. Tried both starter and house batteries. House on 13v due to solar, engine on 12.7v. Done Calder's voltage drop tests, which averaged around 0.2v, so pretty sure not a battery issue.
Done the hammer tapping trick. Can turn the engine crank shaft half a turn (is this an indicator of anything? Should I be able to fully turn it?)
I've read the instructions on stuck pinions but his solution doesn't tally with what I see. Part of the problem is that I'm not sure whether my motor is Inertia or pre engaged. I'm guessing the latter. Here's a link to my starter motor for my Perkins Prima M60: http://www.ebay.com/itm/M2277-Perki...Marine-10-Tooth-Starter-Motor-/280763352325My
My next move is to take apart the starter motor but I'm not sure what to do next or what I should be looking for.
Is it possible to tell if something has just 'stuck'? Is this easy to fix? If the motor has burnt out can I make repairs on board? If the starter motor was working fine one minute and then fails to start half an hour later, is this most likely to be burnt out?
Could do with some pointers here as I continue to consult Calder and start to remove the starter motor. Thank you.
Jamie
Jamie
