AngusMcDoon
I definately considered chopping a well into mine and moving the rudder to the transom when i found out my lump was dead but couldn't figure out how you charged the electrics so my question is how do you charge the boats electrics with only an outboard for power?
The sailboat outboards come with a charging output. It is not as much as from an equivalent sized inboard. Typically it will be 5 to 10 Amps. So, the electricity supply is solved by...
1) Use an outboard with a charging capability
2) Get an additional source, like a solar panel
3) Limit consumption - LED lights and compressor coolbox for example.
I have 6A output from the engine, a 30W solar panel as my source, and for consumers I have a full range of ST60 instruments, tiller pilot, chart plotter, all LED lights for interior and navigation, heater for use when on shore power or the engine is running, Waeco compressor coolbox, VHF, AIS, entertainment radio. I use a 9 hour battery life netbook which I only charge when the engine is on, I have shorepower, or it's sunny. If I want to run the heating off grid then the engine on tickover will keep pace with the consumption and is barely audible inside.
In 10 years of this setup I have never had battery voltage drop to an uncomfortable level. My batteries lasted 9 years before needing replacement, so they were obviously not suffering from their use.
