dave_gibsea
My 1GM10 is now 19 years old and last season it was smoking badly and not producing full power, however it was very reliable and always started first time. I decided to take a look and took the engine out of the boat last winter. The engine was (I felt) in good condition however the cylinder head was almost corroded through at the exhaust port and the mixing elbow had some pin-hole corrosion. The bore was good but a little glazed.
I had the bore honed (at Marine power) and fitted a new rings, I replaced the cylinder head and mixing elbow then carefully put the whole thing back together. I also has the injector checked and re-calibrated and changed all the filters. The engine turns over easily (with the decompression lever up) and has lots of compression with the lever in the normal position, in fact there is so much compression it is nearly impossible to turn it over TDC on the starting handle!
After fitting it took a long time to bleed the fuel through but eventually it started and I was very pleased as it ran beautifully. Since then I have used the boat three times and found the engine very difficult to start from cold. It turns over and over for ages and even using the decompressor for a few turns to get if spinning fast does not seem to help. It fires once or twice but doesn't pick up, after a lot of turning she does start (eventually).
Once the engine fires she runs very nicely, light grey smoke, no problems and she runs up to full revs under load. After starting once during the day she will fire "on the button" every time. Leave the engine overnight and the starting problem returns. One thing I have noticed is that it seems better when the weather is slightly warmer, worse when it's cold and damp.
I always start with the water inlet off. I always leave the engine at TDC-compression when leaving the boat.
I am stumped!! If the engine wasn't running so well once it's started I could suspect things like fuel but it runs so sweetly, revs and never misses a beat. The first time we ran it we motored for over two hours with no problems. I have also re-fuelled with fresh diesel but it made no difference.
