Ammonite
I'm helping a friend out and wondered if any one has any bright ideas of how to align the engine / shaft with the seal in place when the shaft seal used provides zero support at the inboard engine of the shaft? In this case a series one tides marine seal. The shaft has been centred / aligned on the hard using a top hat bush to centre the shaft in the stern tube but I'm concerned with the degree to which I've had to move the engine to line things up ashore and suspect things will be different afloat.
It's a way to check the alignment I'm looking for rather than resorting to an alternative shaft seal or flexible coupling at this stage.
Many thanks
Many thanks
