jimmertek
Hi
I've recently ordered service items for twin KAD32Ps and wanted to ask one or two questions.
Is there a good guide/reference manual/book for the KAD32 engine? I cannot seem to find one which contains the detail I am after (e.g. step by step instructions for each of the following activities).
I'm planning on completing the following activities:
Replace air canisters (screw off/on)
Replace air filters (open up filter box and perform a swap)
Once warm, remove oil using pump via dip stick.
Remove oil filters using filter wrench
Replace oil filters with new (screw on)
Add new oil to same amount that comes out.
Remove old fuel filters using filter wrench
Replace fuel filters with new (screw on)
Hand pump new fuel through the system
Replace racor filter (done this one before!)
Replace aging battery with new model (checked correct model number).
Check/replace impellers
Check oil levels using dip stick
Restart engines and keep fingers crossed!
Is there anything I'm missing in terms of bleeding systems? I cannot find anything online but don't want to start the engines and break something!
Thanks in advance,
Jim
Thanks in advance,
Jim
