Engine room whistle
drewdles
New Member
21 Mar 2011
Broom 35cl twin Volvo 130 HP. A loud whistle in the engine room has started on 1 engine when warm after 1500 revs. It stops when throttled back and returns after a few minutes. Any ideas please
most likely noise from turbo, could be:-
all lead to more noise, worse when loaded.
small hole in exhaust before water injection
air leak on induction side,and on the boost side including loss of air cleaner, (mentioned earlier).
dirt clag etc on induction side in the turbo, and inter cooler if fitted, leading to overspeeding of turbine
excess carbon on exhaust turbine, and after area.
turbo out of balance, more whistley the worse the balance.
bearing failure started
