xeitosaphil
I'd expect to see more current if the batteries are only 83% charged and the alternator is delivering 14.6v. Alternators can't "reduce charge" - they simply work at a set voltage, the charge rate is governed by the battery's ability to accept charge at that voltage.
You've spent a lot of time fiddling with what must be the cheapest ammeter on the market. Do you really not believe that the ammeter might simply be junk?
Hi Pvb,
" You've spent a lot of time fiddling with what must be the cheapest ammeter on the market. Do you really not believe that the ammeter might simply be junk? "
I couldn't agree with you more, and I’m getting a little exasperated by it all now. I expect that the ammeter is junk just like you said. Not sure if it’s worth sending it back and demand a replacement as the cost could be as much as the purchase, and more important than that is the time in doing so. I need to get sorted out now putting everything back together for the coming season.
Have you any suggestions for a reasonable priced alternative stand alone Digital Ammeter for under £100 that is not part of a combined battery monitoring system, if so would appreciate a link.
