MYStargazer
I’m taking a couple of 6-cylinder Ford Dorset engines out of my aft-cabin Weymouth 32. She’s on the hard. There a travelift onsite with a crane high up on top of it. The boats are tightly packed in, so there’s no room to get a fork lift anywhere near to the sides. There is only one door – on the port side – with a smaller window on the opposite side of the cabin.
I’m planning to remove the engines by:
1. Buying a job lot of scaffolding and making up a frame that reaches through the boat
2. Using a chain hoist, attached to large shackle, to lift the engines before sliding them out, using grease on the pole rather than a wheeled pulley as height is tight.
I will have removed the gearboxes, flywheels, heat exchangers and manifolds first, and expect the remaining engine to weigh about 400 kg.
Is this the best route?
Would a scaffold pole take this kind of weight?
