RupertW
I always close all seacocks (except cockpit drains) if leaving the yacht for a couple of weeks or more. Then tie a string on the morse lever to remind myself the engine raw water intake is shut. This seems such a simple precaution, which takes not 2 minutes, that it is hardly a matter of "weighing up the risks".
If you are not going to bother, I'm tempted to wonder why fit sea-cocks in the first place? In any case, even if they are there, chances are they will have seized or broken if you don't exercise them from time to time.
Incidentally, a few years ago a yacht sank in a marina where I was based, as a result of a failed hose clip on a seacock that had been left open. Oozing diesel then made a terrible mess. So it does happen.
Well that’s not going to work - why would a guest or mechanic be a mind reader and know whet the magic string meant?
