Zing
Fit a gauge to buy a cheap thermometer, or get an infrared one, useful for lots of things. I think the main problem if you regularly shut down before the oil has got hot is that you will not boil off any water in it and risk slowly corroding the engine. As you have a turbo, don’t forget to cool it off properly before shutting down to avoid carbonising the bearings.In the absence of a coolant temperature gauge, how do I ensure that the engine has reached normal temperature before shutting down and hoist the sails? Is there a rule of thump? I will warm up the engine by starting, leaving the marina and slowly reaching cruising rpm (75-80% of full throttle) but then for how long do I need to run it at these rpm? Engine is a volvo penta d2-75 (turbo charged) if this matters?
