Rivers & creeks
I hope we can solve this. Here's the story so far. We have a Thornycroft 230, works well, very little smoke. Compression tested 18 months ago and compression about 90% of 'new' level.
Suddenly on Friday we had a large amount of white smoke from the exhaust that turned out to be steam - vaguely present at tickover but lots at 75% revs. Stopped engine, checked raw water strainer and found plastic in it, we removed that and restarted and all the steam disappeared.
Next day no problem. Sunday we had steam again! This time we thought we traced it to a slightly crushed exhaust hose that injects the sea water into the exhaust elbow. Replaced and carried on.
Today did a routine check in the engine room after the engine had been running for 15 minutes - smell of burning and the inside of the Jabsco raw water pump was literally red hot! It's the centre cut away in the photo. We stopped the engine and a biggish puff of smoke came out.
We checked the raw water filter and it was packed with fine weed. We emptied, cleaned and restarted but the steam was back, lots at high revs, almost none at just over tickover up to 1000 revs.
Things we've done over the last few days:
Changed impeller.
Checked raw water seacock inlet
Removed stack and cleaned it (perfectly clear)
Emptied and refilled fresh water
Engine oil and fresh coolant checked every time we set off, unchanged.
Exhaust elbow removed last year and very clear.
Last year we replaced the main water pump. We were getting squealing noises like a slipping belt, but noises suspected to be from the water pump which was a bit rumbly when we took it off. Noises came again this weekend so maybe they were coming from the Jabsco? Hard to tell with a big old lump chugging away.
So any ideas why we're steaming? Was the Jabsco knackered today? We're holed up in Brighton on our way West and advice, suggestions and questions are very welcome,
Simon
Changed impeller.
Simon
