fisherman
I have a 1.5 in Jabsco for deckwash and bilge, probably 200 litres a minute, depends on pulley sizes. What you have is a manual clutch so you would have to get down to the engine to engage it, and repeated engagements will wear the clutch until you have to unlock the ring and move it round. I used to have that, operated by a morse cable, now I have the electric clutch version, not touched it since 2001. BUT, that one relies on the electrics being intact to keep the clutch engaged. Drawing through a manifold from either seacock, engine room or forward bilge. I also have a Johnson L 4000 electric pump. Bilge alarm is most important, just a magnetic reed/float switch to a buzzer, forewarned is forearmed.
