Men a vaur
New Member
Hi Everyone
I’m continuing to have overheating issues with my MD2020 engine. I’ve replaced the temp sensor and the thermostat for starters but have not solved the issue. The symptoms are as follows:
- Engine overheating alarm sounds when engine is in forward or reverse after a few minutes.
- Heat exchanger doesn’t appear to be overheating
- Calorifier is not heating domestic hot water
- Domestic water tank is draining within 24 hours of filling up with all taps closed (seems to be overboard as there’s not much water in the bilge)
- Plenty of raw water coming out of exhaust and not excessively hot (eg no steam) making me think it is the freshwater system that is causing the issue.
Things I’ve done to try and resolve so far:
- New thermostat and temp sensor
- Heat exchanger has been removed and cleaned - all debris removed
- New hoses fitted to fresh water system and spigots cleaned
- New raw water impeller fitted and gasket replaced
I’m a bit unsure as to how the domestic water tank is draining 70 litres in less than 24 hours but suspect this is all connected to my overheating problem and am wondering if I have cracked pipes/ a leak in my calorifier between the domestic water system and the engine coolant/freshwater loop. However, I don’t understand how this would cause the overheating problem. Has anyone experienced anything similar or have any suggestion/advice on how to resolve this?
thanks very much
thanks very much
