Mike ROAM
VETUS M3.09 25HP 3 CYLINDER aprox 5 years old 620 Hours
OVERHEATING.
The engine will run happily all day at around 1500 RPM but ... once the revs are increased
it will overheat in a matter of minutes triggering the warning light buzzer at aprox. 90
Centigrade and the temperature will continue to climb.
Plenty of water comes out the exhaust which is not at all hot. The exhaust elbow does not
get hot.
There appears to be NO problem with the raw water system.
I have performed the following WITHOUT improving the situation.
The tempreture sensor was placed in a kettle and boiled. The temperature guage showed
aprox 100 centigrade as it should have.
The engine has been run without the thermostat and still overheats.
* Replaced the Raw Water Imepllor.
* Opened both heat exchanger end caps and cleaned through each individual tube
thoroughly. ( Some were very clogged and I thought I had found the problem... again it
made no difference ).
* Replaced oil and Filter ( at it was on the overheating Troubleshooting List ).
* Checked V Belt Tension.
* Made a visual check of the Coolant pump ( usually it is the baring that goes on the
pumps and they become a little wobbly ..it appears fine.
* The coolant pump appears to pump well.. engine was run at idle speed with the
thermostat housing open with thermostat removed watter was pumped into the housing
and flowed over the top.
* I have removed the coolant pump intake ( pipe below the pump ) and blown hard on
it.. water seems tocirculate well as it begins to pour out through the top of the
thermostat housing which would indicate that there are no blockages.
* I have removed the exhaust and the exhaust elbow to look for excessive carbon build
up. It was only slight and removing it and replacing it made no difference.
Observations:
When I look into the top of the heater exchanger .. which is also where one fills the
coolant ... it appears that there is hardly any movement of the water .. it really only looks
like the only movement is from the vibration of the engine.
There is no oil in the coolant and there is no coolant in the engine oil.
Any help woule be greatly appreciated...
Thank you, Mike
OVERHEATING.
get hot.
Observations:
Thank you, Mike
