colin.marshall
Trying to diagnose a problem where my lister petter 3cylinder marine revs to limit when in neutral.
This first occurred after initially the engine revs lowered when motoring. With no fuel gauge I topped up fuel and all seemed fine until I next put in neutral. This could all be coincidence.
I had recently replaced raw water shaft seals. A leaking oil pressure switch. Replaced oil filter and oil too.
Trying to sort this I have since replaced primary and secondary fuel filters and bled system. Engine does start but still it revs high. Whilst I cannot control this with the throttle, I can can control revs by half closing the engine stop. I welcome any suggestions and have some questions to start.
Can air in system cause the engine to rev like this?
I am assuming the fact I can easily stop the engine means it’s not sump oil that’s feeding the engine?
Does the fact the engine stop can control the rpm mean the injector pumps and fuel rack are ok. I am believing the engine stop adjust the fuel rack via the governor?
Accessing the governor and trying to repair would be new to me so I’m trying to understand what might be going on.
