CCJ
What sort of boat has he got?
Read "Most engines" that just about covers it
I shall not be running it, I will change the oil cold.
You seem to be at variance with the other posters. I hope your good fortune continues. T.
You miss the point. Yanmar specifically outlaw the use of synthetic in the handbook.
I have a yanmar 3gm30f and I need to change the oil and filter again (I used synthetic oil when I did the change at layup). The boat is out of the water and I am wondering if the closed freshwater circuit will be enough to protect the engine if I run it to warm the oil prior to extraction. I would leave the saltwater pump inactive unless I have to arrange a cooling water supply.
Could this damage any other engine component.
TIA. T.
