Ink
Some good tips there, thanks.
A fully charged battery is a given as new ones will be required. I'd also use a jerrycan of fuel as what's in the tanks may be pretty buggy and will require polishing or discarding. Not so sure about using a hot air gun or fan heater to warm the oil up, it's a big lump to heat up, but I'll bear it in mind.
Once you get the engine started I would then change all the belts. They will have been sitting in the same position all that time which doesn't do them any good.
Ink
