rajjes
Hi,
My engine reaches 3000 rpm on full throttle on neutral. On engaging gear the revs climb from 900 to 1600 rpm at ½ throttle, but do not go beyond that with additional throttle!
The specs are as follows:
2 cyl Kubota – 10Hp
Max revs – 3000 rpm
Gearbox ratio – 2.2
Waterline – 21 ft
Displacement – 6000 lbs
Propellor – 13 X 12
Using the available programs, such as the castle marine, the prop pitch seems about right, and there is no noticeable fouling on the prop, hull.
Is there anything I can check before trying to lower the prop pitch / diameter
2 cyl Kubota – 10Hp
Max revs – 3000 rpm
Gearbox ratio – 2.2
Waterline – 21 ft
Propellor – 13 X 12
