Elessar
A duvet for a heat producing engine, what could possibly go wrong?
Did you miss the fundamental point that most marine engines are not air cooled?
Would only reduce the high frequency noise. Diesel engines have a lot of low frequency noise.
The blankets have 5kg per sq m of lead in them sandwiched between the foam. It’s mass that reduces low frequencies.
No, but when I gain access to my engine it feels hot to touch after about 30 minutes.Did you miss the fundamental point that most marine engines are not air cooled?
I'd rather the heat be radiated into air and moved through the ducting system and drawing in cooler air rather than have it trapped in a nice cosy duvet.
Within out getting my old books out and doing the maths I'd rather the heat be radiated into air and moved through the ducting system and drawing in cooler air rather than have it trapped in a nice cosy duvet. If it was more efficient to have the engine wrapped in a thermal layer then I am sure the designer would have incorporated it in the original design.
