dunedin
We had to replace the throttle cable on our 10 year old Yanmar last year.
When swapping them over the engineer pointed out that the splines holding the throttle lever were very worn. Can't understand how this could be the case but they definitely are worn.
Last weekend the lever was slipping. Tightened up the grub screw but slipped slightly again when coming in.
Would be nasty if level slipped when parking and failed to engage reverse.
Anybody come across this issue? Wondered if possible to drill hole and replace grub screw with bolt. Or is it necessary to replace the whole mechanism?
