Tim O
Following on from my previous threads....
Engineer came to check out my engine last night.....On the positive side, we sorted, at least for now, the leaking stern gland.
On the negative, we discovered the following:
Engine not firing on one cylinder
Excesve vibration, with engine mounts probably needing replacement
Morse gear cables incorrectly set up.
So, first priority is to sort out the misfire as unless the engine is running smoothly, we can't really set up new mountings properly, and the gear cabling is just a tweaking job hopefully.
You may recall history is boat been out of water 10 months, back in, engine running beautifully out of gear, smoothly and purrng like a kitten.....Took her out for half an hour and returned with these issues!
Have changed fuel filter.....Engineer examined the fuel in the old one and said it was pretty clean looking, certainly no sign of diesel bug.
He is going to try compression test on misfiring cylinder, then look at injector, then fuel pump to try and narrow down the problem
What are people's thoughts on most likely scenario here? Engine is Beta v1505 38 HP.
