skyflyer
Yanmar 3GM30. Fine all last year apart from very rough running (vibration) at low RPM; laid up for winter, and on basis of same advice from several different sources, decided to have injectors recon'd. All the winterisation, service and re-commissioning was done professionally - I was busy on other jobs!
Last friday we ran it on the hard (with water connected!) and all seemed fine apart from a brief period when there was a rattling noise and a slight drop in revs - but no vibration. This went after about 30 seconds. The 'on the spot' diagnosis was air in the system from incomplete bleeding (fuel filter had just been replaced). Engine ran smoothly then for about 15 minutes.
After launch later that day I have only motored a very short distance to my mooring and into and out of the marina, briefly, until today when i went for a bit of a run, (to test the new a/pilot rather than the engine) but never above 2000rpm
The rattling noise returned - sounds like theres a handful of small nuts and bolts in there - and as well as an RPM drop i noticed the exhaust was giving off clouds of smoke, bluey white rather than brown, which I take to be unburnt fuel? I was reluctant to open up the throttle, if there was misfiring. There was no obvious vibration however.
Two questions arise:
1) what is happening?
2) could it be connected with the work done on the injectors?
I have some theories but would welcome other thoughts - especially as my detailed knowledge of diesels is somewhat limited!
