superboots
I have the standard VP instrument panel for my TMD22P . I'd like to upgrade to the De-Lux panel which has in addition a water temperature gauge and a oil pressure gauge. I managed to source a VP panel but I think this was for another engine as the rev counter is calibrated for higher revs. It came with its own 16 pin harness cable. I initially tried to connect the cable to the socket on the engine but could not manage to plug it in - was this my fault or are there different connections for panels? Hoping I was at fault and there is no compatibility issue with the panel I have also bought senders for oil pressure and water temperature but do not understand how to fit or to wire in . Any advice before I start this job much appreciated.
