Wansworth
She says I am not fit to captain a yacht ,I will have to start jogging,how awfully middle classYou need to play the sympathy card if that doesn't work try begging.
Don’t think that will cut much iceJust tell her she won’t be getting any ( unspecified )until your toes are wet
Tricky customer you have thereDon’t think that will cut much ice![]()
I must have missed something in this saga... You mean you don't have a paid crew?? That really is middle classShe says I am not fit to captain a yacht ,I will have to start jogging,how awfully middle class![]()
She still loves meI must have missed something in this saga... You mean you don't have a paid crew?? That really is middle class
As for the sympathy card, prob used that up, plus a bit, with your recent enforced sofa time.
Just tell her, "love me, love my boat"She still loves me![]()
That might just test the relationship and definition of love...Just tell her, "love me, love my boat"
Yes this installation had side panels even so the owner took five minutes putting back the dipstick![]()
From on site inspection I managed to lay down on stub bunk alongside engine with visual of oil filter,secondary fuel filter,the first is mounted on port side independent ofthe engine the water pump as you say faces aft,personally I found it possibly impossible to change the filters and impeller fro my position ,but I think by dismantling the surrounding panelling and the bunk structure I should be able to face the side of the engine to effect changes.Interestingly the owner intimated in fact he employed a mechanic to do the engine maintenance that’s why he had trouble with dip stickHaving looked again at the broker's photo of the engine in this boat it looks like there's relatively generous space (as these things go in small boats) to either side of the engine. I can't see from the photo how much space you have above it (Limited height above might, among other things, have made it more challenging for the owner to get the dipstick into its tube.)
Having reviewed that photo and the Vetus engine manual, the only thing that looks meaningfully problematic is the fuel filter on the back of the engine, and that can relatively easily be moved somewhere better. (A few plumbing fittings, flexible pipework, and a bracket to hang it from.) Even without moving it, it doesn't seem to me to be a reason to dismiss this boat. An irritation/inconvenience, to my mind, rather than a deal-breaker.
Oil and coolant filler openings are at the top, front of the engine.
Oil filter is on the stbd. side, c2/3 of the way back, which should be reasonably accessible (as these things go) from the front of the engine, and presumably also via the opening side panels you mention.
Oil dipstick is on the stbd, side of the engine, c1/3 of way back, and presumably reachable from the front, and not need to access via side panels.
Fuel filter on the back of the engine is a nuisance, but it should be easily movable to somewhere more accessible. (Vetus sell an optional extra to reposition both oil and fuel filters on front of engine, but you could probably do the same for less money.)
Raw water pump is at front stbd. of engine, albeit facing backwards. It looks to be easily reachable from front of engine (but would help to have a mirror to see what you're doing), and/or via side panels.
Apart from the engine,as you ask,I t was in excellent shape and everything welllooked after.The owner is a yacht master and anal about paperwork and engine manuals but the boat was not over complicated with gizmos thank god as Iusually have brain cut off looking at dials and switches.If wedid buy it I would seriously consider rails from the cockpit to the shrouds asthe handrails are on the deck and ok if your crawlingAnyway, never mind fripperies like engines, what was the rest of the boat like?
My last boat presented a challenge impeller wise and that was looking at it front onJust use a light and a mirror glued to the overhead , it’s-not-an-issue
My last boat presented a challenge impeller wise and that was looking at it front on![]()
On the old gm yanmars you quickly learn the water pump work around -which is to kinda rotate the whole pump mounting 180 degrees and then work on it.My last boat presented a challenge impeller wise and that was looking at it front on![]()
