blackbeard
I'm sure this has been discussed before but I don't remember any definite conclusion.
When sailing at a reasonably brisk speed under sail alone, the propeller on my boat turns. It's a two bladed prop driven by a Yanmar 1GM, shaft drive, usual gearbox.
This can be prevented by putting the engine into reverse gear when the engine compression stops the prop turning. (Oddly, this doesn't seem to work in forward gear).
I've heard it said that allowing the prop to turn will lead to excessive wear on the gearbox (although it does seem unlikely that this will amount to much).
(I've also heard it said that with a saildrive, excessive wear will occur if the gearbox isn't in neutral!)
The effect on boat speed of selecting reverse gear seems to be negligible although I have been told the boat will be marginally faster with the prop not rotating.
Does anyone actually know if I should engage reverse gear when sailing? Or should the gearbox be left in neutral? Or does it make no difference?
<hr width=100% size=1>
