sailorman
My boat has a 16-18hp 3cyl perkins running a 13"x 8 pitch 3bladed prop. Her displacement is 3.2 tons and she is a long fin keel (6-7ft long) her hull profile is identical to the Elizabethan 30. her max speed under engine is 5kts in slack water, but when punching into any choppy she struggles to top 2-3kts and can very easily fall far behind when in the company of a Snapdragon with a 1GM10 and a Foxhound with a 15hp outboard, although she can easily outrun them under sail.
Why is she so sluggish under power, could she be under proped, needing more pitch, or under powered>
I have been told that if an engine (Diesel) does not give an initial puff of smoke when fully opened up then she is under proped.
What does the board think?
C_W
if it over revs = under propped
if loadsa black smoke & doesnt increase revs no matter how much more throttle you give it = over propped
she should give hull spd (or a little less ) @ max rated revs
