Caer Urfa
Last year removed ALL the existing microbore copper tubing and existing filter and removed tanks to clean.
Fitted a complete new Diesel fuel system, 'ALL' new valves, 8mm & 6.5 mm approved rubber pipework, Pre-filters, none return valve etc everything, also cleaned out tanks.
Each Tek Tank now has it's own filter system
I can run off either tank, or both tanks, but usualy run off one tank at a time
Engine 27hp Isuzu
Problem: After say 8 hrs running at 2000rpm engine just shuts down.
Bleed engine and it will run another 8hrs!
We suspect somehow 'engine is slowly sucking in air' and builds up BUT FROM WHERE?.
Have checked most things three times, everything is tight, diesel is clean and from reliable source.
Any suggestions to next move appreciated ????
Engine 27hp Isuzu
