VicS
Hi Aidan
Incidentally, when I ran the engine for 40 mins before the second outing the engine wouldnt shut off by using the key. It turned out the start battery had been (incorrectly) shut off after starting (alternator should still output through the VSR?) , and the ignition couldnt stop the engine. When the start battery switch was turned on again it worked ok. I dont know if this throws any more light on the matter.
That I'm afraid totally confuses me.
It may be that the "ignition" switch is in an even worse state than peviously supposed or that the "stop" system is not how I assumed it to be. I assumed that there would be a solenoid operated valve in the fuel line which opened when the solenoid was energised and closed again when de-energised, just like the arrangement in a car. I suppose a motorised valve is possible, operated via a relay like a motorsed valve in a domestic central heating system, with the supply coming fom the starter battery. That it beginning to sound very improbable though, unnecessarily complex and heading for a situation where you can't stop the engine in the event of a toatal electrical failure (In which case there must be an emergency stop mechanism somewhere. There is one any way on the CAV injection pump on my Peugeot car but there was not as far as I ever discovered on the Bosch system old the old Fiesta.)
May be it is the ignition switch that is at fault and that switching the battery back in was just a coincidence.
I have to admit I don't know the answer to this one without access to a wiring diagram, but I would definitely still take a good look at the switch. Perhaps connect a voltmeter (or a bulb) to the solenoid energising wire before connecting up the new motor and make sure that every time the switch returns from the 'start' position it does truly break that connection.
It does sound from "all the components are green with corrosion" that the electical system could do with a bit of refurbishment but I guess the complete panel and loom are not going to be cheap.
I do hope you have not also damaged the alternator by disconnecting the battery, that really would be unfortunate. Provided the VSR had switched the other battery in it probably saved the day. I'm glad I have been able to to do all my serious sailing in a boat maintained out of someone elses pocket, even if I've helped do a lot of the work.
Vic
Vic
