Paulfireblade
So, I have an extractor fan in the engine bay running from a fused relay and the signal line comes from the red wire going to the ecu, so when engine is running relay runs the fan and when engine is turned off the fan goes off so all good except at night after we turn off the two pole battery isolators for the engine.
With all power disconnected from engine the extractor will run randomly for a few seconds repeatedly from time to time.
I replaced the relay but it still did it, so I removed the signal wire from the relay and there is generally 0.8 - 1.0 volt on the wire coming from the engine electrics when the neg and pos from engine battery isolated and sometimes it climbs briefly to 1.7 volts which is then enough to operate the relay.
So I appear to have one or two stray volts flowing around my engine electrics which doesn’t sound great.
Could it be a problem with the Split charger feeding voltage back through alternator?
It is a VP D1-30, where should signal line for extractor be taken from.
If it wasn’t for the extractor I wouldn’t even know about the random voltage in my engine circuit when supposedly disconnected.
Any ideas anyone, please.
