TactilePaul
Hi, can anyone adivse me as to the dangers of running coolant with little air expansion and instead a tube running from radiator cap blow off valve to an unpressurised bottle?
the cap (Volvo MD2030) blows at 75Kpa , I have no idea whether it reaches that pressure with a healthy air gap as we have not had any way of knowing if its blowing air out.
Obviously I don't want to put the system under uneccesary pressure.
Back story is that the Volvo method of attaching the pressurised expansion bottle to that cap was flawed, the cap seat is only glued on and is not built to withstand the vibration that came from the substantial brass manifold and hoses!, it failed, repeatedly, a dangerously poor bit of botched design!
so, as hoped, the water pump happily blows all the air from the hot water cylinder heating pipes that are higher up, our only issue is that we have no expansion other than the air gap above the copper matrix taking the raw water through, we have it just above those pipes and so far so good, but i have now attached a bottle to the small brass pipe so that we can see if the water makes it to the cap and the 75kpa is reached and maybe start raising the level so we don't have to worry / check it so often.
the cap sucks back as engine cools, I think at very low pressure judging by the spring ( so it is ok to remove and replace a rad cap when engine is hot as pressure equilibriates when cold?) so maybe we could fill right to the top and put some in the bottle and watch i go up and down, but I realise that the system will be running at 75kpa when up to temp. What about a cap that opens at a much lover level?, i realise that this lowers the boiling point!
any advice welcome.
Thanks.
NB mix of correct and lay terminology intentional!!
any advice welcome.
Thanks.
