scottie
I have used the cheap oil pump from aldi with the pipe down the dipstick and it compared well with the proper jabsco units
It is light years ahead of the Pela
How so?
Can't fault my Pela TBH, apart from being an old one with only one size of suction tube supplied.
I've sorted some alternative tubes for it, including one with a 1/4 turn valve which makes life easier when cleaning the bottom of diesel tanks.
It's very slow messy and bulky both to use and store apart from that it leaks
dunno what a D2-4 is. VP site does not recognise it. .
I have seen a tip for getting the oil out faster. A piece of 12mm plastic tube can be pushed over the dipstick tube and makes a good seal. You need to check if their is a small air bleed hole near the top of the tube and push the plastic past it. Connect the other end to the Pela. The problem with the Pela is that the bit that goes down the dipstick tube is just plastic covered curtain wire and has only about a 3mm bore.
I have not done this yet, but intend to when I go back to the boat.
Plus one, so check first that it goes all the way to the bottom. My VP MD22 has a dedicated pipe at the front that you take a plastic cap off and attach the Pela tube to. I sorted out a bit of cross over tube to suit. The VP 20x0 series has a similar pipe on the side that does the same trick.Dipstick tubes rarely go to the bottom of the sump, they're often a press/hammer fit about 3/4" to 1" into the block.
D2-40, the 0 fell off!
I'm struggling to see how that would work - I get that the dipstick tube "SHOULD" act as the bottom bit of the pela ( just larger bore) but isn;t the rest of the oil system effectively sealed - so you will end up creating a partial vacumn that you then need to overcome? be brilliant if it worked though
How so?
Numpty question of the week....
How long should I leave an engine (in this case a yanmar 3jh4e) to cool down before taking out the dipstick to drain the oil with a pela?.
Is this in preparation for the 'big push' or has the shorepower at Brighton failed again???:encouragement:
Big Push to actually move this boat somewhere...*anywhere*...before summer ends, yes. Now if only I could find the answer to my transmission oil question and find a strap wrench to get get the primary fuel filter off I'd be ready to...errr...well get the bottom pressure washed and change some anodes...
