zeehond
This may seem very strange to all you practical guys out there but It seems the engine beds on my 1992 Warrior 40 are not correctly aligned with the propshaft - a misalignment of 9 degrees. The beds are parallel to the waterline and the shaft is inclined downwards at a 9 degree angle towards the stern. This means the mounts are seriously deformed as the back end of the mount is metal to metal.When I bought the boat, 7 years ago, the survey did not mention this.
I had the mounts replaced 6 years ago; the mechanic said the back of the mounts " might" hit the fixing bolts and I should consider using a Dremel mini-grinder to take away the lower rear end part of the metal of the mount to prevent this occurring. He did not say the beds were the problem. I did not do this as it was downplayed, not critical.
Earlier this year,, a survey highlighted this issue, saying that action needed to be taken as metal was/is being worn away at the back end of the deformed mount. In fact, we have lifted the boat as we have no confidence in the installation.
My thoughts now are how to correct this. 1) Remove the engine and redo the beds. Obviousl the ultimate solution but to remove the engine from its central position in the saloon is daunting. 2) Remove the engine brackets sequentially with the engine in place and cut and weld in the correct shape. Once remade reconnect them to the engine in such a way as to allow the mounts to be properly installed 3) Remove the engine brackets and mounts and do as good a job on the beds as limited access allows (again sequentially with the engine remaining in place) Glass-in a wedge of hardwood 1:11 (9 degrees).
Any thoughts/advice on this will be welcome. The engine is a Perkins M60 with Hurth 250 g.box and weighs just under 300kilos I believe.
