boatone
You may remember my earlier post on this topic following the extreme low temperatures we experienced in December.
Following this, I realised that the electricity meter I was using was faulty and subsequently took it out of service so I have not been using any low level heating in the engine bay at all.
A couple of weeks ago I bought a temperature logging device - a bit like a USB stick but it records temperatures according to criteria you set up in the software.
I set it to record every hour and left it in the bottom of the engine bay and you can see the results in the picture.
As you can see, from 20th to 29th January the temperature hovered between +6 and +4 Celsius with the measurement point in the bottom of the boat just on top of the keel - so about 2 feet below the surface.
Comparisons between this device (which I regard as calibrated and accurate) and the B&Q min/max thermometer show the min/max to be reading a little lower with a min +2.5C over the period.
I am considering getting another logger so that I can track comparative temperatures between the upper cabin or air and the engine bay.
OK, maybe a little anal but interesting I think ......
