oldbilbo
I'm considering fitting a facility for one form of emergency steering, and invite comment. The intention is to fit an eyebolt with a corresponding eyenut through the rudder ( see below ) at about half-height and one-third span from the trailing edge. This would be fitted through a s/s tube epoxied in place, and with over-sized s/s washers, to prevent compression damage.
The plan is, in event of tiller failure and/or failure of the top of the rudder post onto which the tiller clamps, that control lines be secured by snaplinks to the two eyes, which are then led diagonally via blocks on the toerails further forward and so to a 'whipstaff' control lever in the cockpit. An existing double-ended spinnaker pole, with sheave blocks slung from both ends, could be secured across the cockpit in front of the sheet winches to give a better lead.
Of course there are limitations and constraints with that arrangement - which was once common practice on sailing ships. Attachment of the lines would need to be done at the first sign of tiller problems and in any event in moderate sea conditions, for it would entail someone going over the side. Any other considerations....?
