prv
What sort of output does that produce? And I'm guessing it's either 5v or 3.3v?
NB, I still disapprove of indoor GPS antennas, but something like this could be mounted outside quite easily.
...for values of "quite easily" that include building the whole enclosure yourself
The BR355 is waterproof, so you could sikaflex it to the deck as-is with the wire going through a gland - if you wanted to. Although I have mine cable-tied to the top of a bulkhead just below the side-deck and it works fine. My AIS display, which it also feeds as well as the radio, has a GPS signal strength display mode and that invariably shows lots of nice big bars near the top of the chart, so I'm not worried about signal degradation at all. My elderly Garmin 128 did occasionally lose fix with an aerial in a similar position (since moved), showing that your disapproval was once grounded in fact, but twenty years of GPS receiver development have happened since then.
