Emergency Alternator belt
Sam_Steele
22 Apr 2003
Winchfield, Hampshire
www.circumnavigation-uki.co.uk
I once saw an emergency alternator belt that was a single length that you could join, incase one broke. I do inspect the belt daily and change when needed, but you never know when you might have to change it at sea.To change mine, I have to remove the hoses to the water pump and whilst this is fine when tied up, I don't fancy trying that whilst the boat is going up and down. But I can't remember where I saw it or who made it.....does any one know???? Many thanks Sam.
Robin
30 May 2001
high and dry on north island
We bought ours in a car accessory shop. Have never had to use it but we routinely change belts at the annual winter service and keep the old ones as spares - we have quite a few spares! We do have 2 alternators and Advercs so they do take some load during the season, I'd rather change them too often than have to do it at sea. We do the same with water pump impellors and have a fine collection of these as spares too!
Johnjo
8 Sep 2002
Had a simular set-up once, overcame it by fitting two belts , tieing the first belt back out of the way of any moving parts, then fitting the second as normal.
So if one belt failed you had another ready to fit without removing any piping etc.
Up and running again within minutes,
Talbot
23 Aug 2003
Brighton, UK
Think you will find that <A target="_blank" HREF=http://www.motortraders.com/xcart/catalog/product_17105_METRO_Emergency_Fan_Belt.html>This</A> is the fan belt that you cut to size.
Keith
9 Dec 2003
andros bahamas
I had one fitted on a volvo MD7 with a %%amp alternator and it shredded it, i think they are OK for cars where the loads are light, but after a night out at anchor and the batteries pulled down thats when they let go.........keith
Keith
9 Dec 2003
andros bahamas
Sorry, brain fart, forgot to take finger off key!!!! should read 55amp alternator...keith.........and no i didn't review my post either!!!!, but i will now.................................................
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Yes, that's what I do.
andyball
1 Jun 2001
asap-supplies sell something that's meant to be rather better than the ones that break; haven't tried them, but worth checking.
TheBoatman
12 Nov 2002
Kent
I think you are talking of Bremmer belting. You can buy it by the metre at your local bearing/transmission suppliers. Check in your local yellow pages.
William_H
28 Jul 2003
West Australia
If you look at any single engine light aircraft with Lycoming engine you will find a spare alternator belt tied back ready for fitment as you have to remove the propeller to fit a new belt. As suggested you should do this on your boat with a replacement belt. Tie it back with soft wire or cord ready for use and replace it another day.
